Idle Speed Only!!
mike martinez
Premium Member
Premium Member
Its me again i dont know what else i can do to my ski it idles but when i give it gas rpms go up but ski moves about 5 miles per hour i checked to splines on the pto they are good i changed my drive shaft i checked the splines on my impeller good i changed my wear ring i checked the distance from impeller to wear ring good i cleaned the back of the ski where it has silicone where pump goes in and put new silicone is there anyone that can help me please before i burn my ski thanks.
Mike, did you use all the same parts? If you replaced parts are they the correct ones. Is the clearance between the impeller and wear ring .040" or about 1/16 of an inch? is the shaft attached to the engine? It doesn't make sense....:ack: Recheck all that you did, if still can't figure it out add some pictures to the post.
Karl
