Ibr delete
amigo32
Hello fellow riders
I was just wondering if anybody has used
A Dashpac ibr delete if so How does it work?
You would loose only Reverse, Neutral and trim ? Other than that your jet ski will run forward with no issues
Tia.
It is a plug and play thing, designed for racers.
If you only want to go forward...
Thanks rikky
I just dont want to pay another $1200 for an ibr actuator its a 2010 gtx 155 mine broke and iam thinking of just getting the Dashpac ibr delete
Your call but only forward movement and no going backwards. If you launch and recover from the beach no issues I suppose.
What is wrong with your IBR, is it mechanical or is it the electric motor? In a lot of cases you can clean the commutator or fit new brushes and you are good to go. it is a cheap 40 USD motor...
OP did you ever try the Dashpac? I’m on the same boat (literally ) I don’t want to pay 1300 for another unit!
