I would not recommend an SBT motor
kwellmancpa
Just wanted to post some advice out there so someone else don't have to deal with the moronic bafoons at SBT like me. I bought a motor from them, besides motor replaced all fuel lines, pulled tank out completely cleaned and dried and put back in, complete carb rebuild from a dealership. Could get motor to start would not run right, repulled carbs and cleaned and checked, put new diaphram in. Then last thing I think it would be, check the motor, and one cylinder has 140 compression, and the other has 100. Send motor back to SBT, on phone they said it sounds like a lean condition. When taking off my parts to send motor back, looking through exhaust port, can see the the rave valve ports were not chamfered, and the piston has deep gouges in the sides from there. Called them and told them that it wasn't from a lean condition, that they need to advise whoever is building there motors to chamfer the ports. When they sent my new motor, they said I had a lean condition, obviously they do not tear them down like they say. Well, now when I am trying to put together my new motor, the thread end on the pto flywheel side is banged and the thread collapsed, and also one of the helicoils inserted into the block for the two water jackets is not correct and cannot get one of the brass fittings in. Will be calling them today as soon as they open, but I feel if it is this bad, the motor is going to probably be junk too and will have to be sending another motor back to them. Beware, stay away from dealing with SBT if you can avoid it at all costs. I would pay a little more to deal with someone local with integrity that will stand behind their items, and not stick you to pay shipping when you have to keep sending it back even though their screw up.
Opinion, not advice...
I was trying to decide how to answer this thread because it's not truly advice, it's a rant, ...it's an unhappy customer. Its the rambling of someone who is totally ill informed.
Before I get to far in this reply, you show your obvious experience with engine installations by saying, "you took your carbs to a professional "stealership" for rebuild. Can I assume that you also used this highly respected "stealership" to put your engine in?
The reasons you see my negative comments to your rant?.......I"ve ordered and installed 12 engines from Short Block Technologies. Not one, I repeat, not one of them came to me in any of the conditions in which you state yours was.
They are the largest remanafacturer of watercraft engines in the United States. Do you think they got that way from lying? They state, right on their home page and that all remanafactured engines are rebuilt to OEM specifications. Do you think if they were not, that a lawyer would not have already opened a class action lawsuit and shut them down for false advertising, ranking in millions of dollars?
You do not state whether or not the stealership installed the motor or if you did.
SBT guarantees that each remanafactured engine has brand new pistons, rings, rods, bearings, seals and gaskets. The pistons are of a high slicon, hardened, cast aluminum and are "guaranteed" to be of OEM specifications. Because these engines are remanafactured from core exchanges, some have been bored over .010 and rebuilt. The cores that come in and can't be rebored, are re-sleeved and standard pistons installed.
Their engines undergo a 4 point test before they ever leave the factory for squish and compression test, case and waterside pressure test by turning the engines over at starter speeds. All engines compression tests are within the guidelines of OEM specs. IT doesn't mean your going to get an engine with exactly 150 PSI on both cylinders. That's something you might not even see in a brand new engine!
They guarantee not to use any aftermarket parts or do any mill work on heads. If a RAVE is bad, it is replaced.
I think, before you start going out on a limb, showing your anger (and ignorance I might add) in a forum whose members have had 99% excellent results from the use of Short Block Technologies, you should do two things. Go to their website and see what it is they offer you for your business, what they promise they'll do for you, including you screwing up the engine and them offering you a 1 year, no fault warranty and then, doing a little research into why the problems you say you have, happened.
For some reason, I don't believe you installed this engine yourself and if you didn't , then how do you know that some un-experienced mechanic that you hired, didn't drop a screw or something in the spark plug hole, causing this damage.
If I or any of our members had this kind of experience at any other time, I might be more receptive to what you are saying.....but for me, it bears no weight what so ever. I do not believe that SBT is at fault with the problems to your engine but that this damage occured there after.
I do not work for SBT and actually promote www.seadoowarehouse.com, since it's the parts distributer for our forum. But, since the warehouse does not offer engine rebuild kits, I (along with the administrators and other moderators) allow links to SBT to be used in our forum, solely because of their reputation.
So please, the next time you want to show your ignorance, make sure you use the language like, "in my opinion" or "I feel like" or what ever form of language you feel like using, without trying to slam a parts distributer or engine remanafacturer that thousands of people have used and had excellent experiences with because of a faulty installation on your part or someone you allowed to screw up your motor..............SBT is not at fault for someone elses mistakes................
It is so easy to rant on and blame someone else for your negligence. It appears SBT stood behind their product to the letter...You should stand back and have someone experienced install it properly.
Karl
i thought SBT was a pretty cool company, not to many engine remanufactures have how to videos linked to there website for the do it your selfers. just my opion
First off, it went to the dealership because I wanted all the pop off pressures checked and do not have the proper instruments. Second, I have photos of the pistons through the exhaust manifold of where the rotary valves gouged the pistons, and the ports were not chamfered. Now snipe I respect your knowledge, but on this one you are way off. Am I pissed, yes I am, you would assume a motor is correct when you pay that much for motor and shipping. Then when it obviously that wrong or defective, to have to pay shipping again to ship it back to them is ridiculous. Before you just start slamming someone snipe, better ask the correct questions, because although I respect your knowledge, your slamming comments are bullsh*t. Am I an expert, no, never professed to be, do I have above average knowledge, yes I assume I do, but when two other mechanics are with me changing the engine, and they say the same thing, the ports aren't chamfered, and the rave valve clearance was not adjusted correctly and the rave valve gouged the piston. The SBT guy I spoke with said the motor was bored, now if they did not properly check the rave valve clearance, that is where this could happen. But their explanation is that the motor was lean. If that is the cause, then everyone on here saying to run 50:1 mixture in the fuel, plus I also ran the oil injection, properly aligned with two turns in on the screw, then adjust it, then everyone is wrong, huh? Why I will not deal with them is not the fact of the bad motor, but the handling of it, and how they tried to put off any wrond doing on their part, and making me pay the shipping for something that was shipped wrong in the first place. Also, the one rave valve was pushed up hard enough the top part with the boot and everything was messed up, and you could tell it was not right, but did not take apart to check it and photograph it so the warranty would not be voided. Could I have done the same thing rebuilding a motor myself, yes I could have, could have made same mistakes or not, but the idea is, with working so much I did not have the time, so I paid for that service, and it was not done correctly, then I have to incur more cost for them to do it right, that is my complaint.
I'm with ya kwellmancpa. I've seen so many crapped out SBT motors it's ridiculous. And when you take the time to really look at the parts you'll start to see repeating issues like crank welds cracking, misaligned sleeves, incorrect sleeves, and such. Even had one that had the circlips left out. Personally, I think their motors are junk. Are they the largest? Yes. Are they the best? Heck no. Most people like them because of their no fault warranty. I myself offer 2 year warranties on my motor rebuilds I install in house. I've done right at 45 motors this year and all with a 2 year warranty and zero failures. Once you have the opportunity to look at the guts of their product, only ignorance will get you to buy one of their motors.
Oh and snipe, yes I did install myself, just because I am not a moderator as yourself, does not mean I am ignorant or clueless, so come down off your high horse. And for the record, after speaking with a few motor builders that have actually tore into SBT motors, I am not the only one with faults with their motors. Just because they do thousands of motors, but how many failures have they had, you seem to be so smart, what is the success failure rate, exact numbers please or else judging by how you say things, if you can't give precise numbers than that would show ignorance too. I get tired of people telling others or saying someone else is ignorant because they aren't renowned or do thousands of things, or self proclaimed experts as some seem to be. I do the best I can, an expert by no means, but can visually see the obvious.
And lastly, in talking about showing someones ignorance, I would suggest the same to you. You said, before showing my ignorance, to use wording like in my opinion, etc., well, in the same respect, maybe you should read the heading on this topic, "I Would Not Recommend", that pretty much by default reflects that the stated matter is of one's opinion, just for future reference for you.
Please, keep it clean...!
So, you've had your say and in this same response, you seem to be doing one thing, "screaming foul"..........(by the way, I had to edit your language). Although you said, "in your opinion"....you did continue to rant about inconsistencies.
If you've ever read my threads and posts, you see I have said many times over, "I am no better than anyone else in this forum," I only moderate it. I'm not God and don't pretend to be. I'll tell you straight up, Bill O'Neal is the smartest man I have ever met in a forum setting. I have put many people above me. When I read from someone, who has posted their work and experience, I enjoy reading their theory of what it was and how it was that they fixed or replaced it. PWCdoc is someone I highly respect, along with Dr.Honda and Chester. There have been many others come and go but they are still here, for the most part. His knowledge is obviously, very high. Above me?....I don't know. I'm not here to judge that. Wisdom and experience come with age and your success rate in what you've tore into. You decide on how good your getting on small engine repair, by how many motors you actually get running again, not with "school".
I'm not here to slam you, just here to play the devil's advocate because you did not make your thread as informative, you made the thread as a rant. You were screaming foul. Why?....
Here is my problem with your thread, and even still. The very first thing you say you did, "First off, it went to the dealership because I wanted all the pop off pressures checked and do not have the proper instruments". If you have really read through the forum, how many people in here do you see place any trust in what they (dealerships) do? For all we know, as soon as you took it to a dealer, they dropped something in the exhaust port, spun the engine over and damaged it, unless you can counter by some way that when you delivered the motor, you stood over their shoulder the entire time your motor was in their possession. I guess, for me, it's kinda like comparing a pee test. Unless you witnessed this from beginning to end, who's at fault if it comes back positive? Did someone taint your sample or where you actually guilty? I did not say SBT did not send you a bad motor, I simply told you about my experience with them and what I've seen in many motors ruined by novice or beginner mechanics. Does this include you, I don't know. I have no idea of who you are. I only know what I read doesn't fit the timeline.
Again here, by stating "pop off pressures"...then I assume you're talking about your carbs. Since I do not know of any other pop off pressures done on a Rotax engine. If that's the case, the carbs were not together when you took the engine to them (or they were and they took them apart again to check the pop-off). The inconsistencies in your threads timeline is what leads me to this issue of ignorance. Remember, ignorance is not a defamatory word. It only means "un-informed"......that's all. It's not like I was calling you a name. I hope, by pointing out the problems in your story, you see why I have the problems with "ignorance".
The issues with "chamfer".....? Again, from your thread I quote, "the ports aren't chamfered, and the rave valve clearance was not adjusted correctly and the rave valve gouged the piston. The SBT guy I spoke with said the motor was bored, now if they did not properly check the rave valve clearance, that is where this could happen." No, this is not the case. I would have to measure it to prove my point but in my opinion (and experience with the SBT engines), this can't happen and here's why. On the 787cc engine, the cylinder bore is 3.228". This engine (and the 951) is only designed to be bored once over at .010". The reason for this is due to the RAVE clearance. It can be bored over one time without changing the dimensions of the slide valve. You can bore this engine over again, only if you also cut the RAVE down, but a remanufacturer will re-sleeve rather than bore over because of the work it takes to chamfer a slide valve (the exhaust port itself is not chamfered). It's not feasible to spend the extra money and man hours on doing this. Now, if you race and have your own machine shop and time is not of the essence, then you might want to bore over twice and cut down the slide valve. That's why it is not recommended to bore over more than one time. The other 2 stroke Rotax engines, without RAVE's can be bored twice over.
As for the crankshaft issue that PWCdoc states, that is another issue. Although I respect him for his abilities, he's also not in the market to buy those type motors, he's got his own shop. And this is "totally my opinion".....why would PWCdoc say anything good about competition? That takes money from his pockets? You don't hear me bragging about how good any of the other forums are, do you?
Short Block Technologies bought out USA Shortblock a few years back. They have been in business for over 10 years, that I know of. Which means, how many motors?........I have no clue. But, I think (again, opinion) if their product was faulty on a continuous basis, they would be "out of business". One other thing. .....Have you ever read their home page? They state what they will and will not do. What it cost extra and what they will give you. In other words, if they were being deceitful in their advertising strategies, then they would have one suit after the other pending in a court of law for misrepresentation.
Had you made your case in a thread, where you said you got the motor in a crate (they come boxed in a hardening spray foam) and when you opened it, you saw the obvious damage to the RAVE bellows (which would be easy to see, since the caps do not come with them) and looked inside the exhaust ports and saw the gouges in the piston, I'd be all over this and calling them myself for you!!!!!!!!!! But you didn't. Or, that's how you wrote the thread anyway.
I'm always open for debate. When I first read your thread, I saw a very angry customer who did not get what he wanted (or expected). In a forum, it's all in the way you present yourself and from the "get-go" you were very accusatory toward SBT. Never once pointing out that maybe (like I said, unless you were there with your engine, the entire time) the place you took the engine to, might have done something to damage it.
I'm not perfect, example: This past season, I had a guy bring me his GSX. Right away, I spotted the fuel lines (grey) and told him, his problem was the lines and needed replaced along with the carb kits. Well, guess what. When I got it all done, I took it out, it still ran like junk. Then, after removing the seat, smelled the exhaust gas. My diagnosis was wrong in telling him that his carbs and fuel line is what caused his bad running motor, it was a split exhaust hose. But, I did advise him he needed to replace the lines anyway.
So, unless you show me some threads where I have said "I'm perfect" or "I don't make mistakes"....please don't write things that are not true about me. I did not make up anything I wrote in reply to your thread, only what you stated as evident to me through your words.
You are free to express yourself here too, as long as it's in the good taste our forum is known for, not any foul language type responses. In my opinion, foul language is the easiest way to prove ignorance. So please, keep it clean.
:cheers:
HHmm...interesting stuff I guess. While the majority of what Snipe says is correct, I must elaborate on a few issues.
Firstly, Snipe, I do think you came off a bit to negatively to kwell's explanation of his experience. I did not interpret it as anything other than his opinion and he is free to express those opinions.
If you have ever torn into an SBT motor that has been bored you will find, at least from my experience, the bores are all 2nd oversize. So, while Snipe's comment about not requiring machining of the RAVE valve is correct, it is indeed necessary for SBT's tech to machine the valve b/c it will hit otherwise. Why does SBT skip right past 1st over? Not sure but I'll guess that it goes back to when they bought all of WSM's pistons which were coincidentally 2nd over and hence they set everything up to automatically run 2nd whether it was needed or not. BTW, I'd never run a WSM piston either. And yes, the exhaust port is indeed in need of being chamfered. Not doing so will allow the ring to get snagged by the exhaust port. If they did resleeve the cylinder, it will still need to be chamfered but depending on what bore size they put back into it, you may/may not have to machine the valve. Also, you may want to verify that the actual sleeve/s that they installed are indeed the correct sleeves and they match each other.
"As for the crankshaft issue that PWCdoc states, that is another issue. Although I respect him for his abilities, he's also not in the market to buy those type motors, he's got his own shop. And this is "totally my opinion".....why would PWCdoc say anything good about competition? That takes money from his pockets? You don't hear me bragging about how good any of the other forums are, do you?"
SBT doesn't take money out of my pocket...not after the customer has been educated. I'm not in the market to buy SBT's product b/c I have found it to be an interior product. I have installed OEM shortblocks and would do so again if the customer wanted that. It's just very expensive to buy an OEM shortblock compared to rebuilding. And the warranty on an OEM shortblock is to short in my opinion.
Are we perfect? Heck no. I myself have made mistakes but we learn from them and try not to repeat them. But I have not made the mistake of buying and installing an SBT motor and I will never be close to making that mistake.
Also, when customers do bring in their blown SBT motors they, like myself, desire to have all the SBT components removed and replaced with good OEM or comparable components, such as the head that SBT machines to net a less than desirable dome design.
And again, I did not interpret kwell's post as you seem to have interpreted it.
Opinions are welcomed.....
You know, maybe your right! It is a place for members to express themselves but as one who likes to write, not just read, his thread did hit me in the wrong spot.
The problems with the "finger pointing" when there was the possibility of someone or someplace else that could also have been responsible (unless I read it wrong, you were not there with the engine the entire time it was with a dealer) along with the timeline on the chain of events. The name calling (moronic bafoon's) when that entity was not available to defend themselves and lastly; within the last two years I've been here, all the members purchasing their products, not having the problems he did.
Even in this thread, members have chimed in, happy with their purchase. You (PWCdocd) are the first one who wrote of problems that are logical, of concern about the business practices of SBT. If what you say is true, then this would open them up to liable (maybe criminal) lawsuits, since they say directly, on their home page, their engines are reconditioned/remanufactured to OEM specifications. They do state their engines are "standard or .010 inch over", which is within the guide lines of OEM specified. But, if they are jumping to the second bore over size, grinding the RAVE's, this is not OEM. If this happened to me, I would seek legal advice.
I'm not slamming Kwell,....he has a right to his opinion but when he wrote the thread, it was not opinionated. It was more of a rant, with accusations. If you read the subject line, he states, "I would not recommend SBT motor" but then, he goes into a rant about his experience (helix coil use does not violate OEM specifications), telling members to "beware". I think I'm more concerned that he may not have all the information he needs to make the comments he made. Which, if not true, could keep members who operate on a shoe string budget, from seeking out the best way to put their money to use. Unlike you (PWCdoc), many members don't have access to affordable machine services. Or they lack the experience e in tearing a motor down and sending it out for re-working.
It does appear Kwell took my response the wrong way. I did not make it to slam him or anyone else. But, if he goes back and really, really reads it, trying to see what picture it is he's painted, it doesn't seem like all the pieces to the puzzle fit.
Sorry Kwell, my intentions were not to slam you, if that's how you took it. But, go back and read the chain of events. In my opinion, there is too much left unsaid.
OK, I guess to clarify timing I will start at the beginning. I got the 1997 GTX last year. While it still had the old motor in it, could not get it running, compression seemed to be good. My knowledge was still way below where it is now. I took the ski to the dealership to have the carbs completely rebuilt because I was not confident with doing myself, and before I read all the advise in the forums, and now after reading forums for over a year, I am very confident with the help and advise from everyone in the forums including kustomkarl and seadoosnipe. After doing a complete rebuild on both carbs, the dealership told me the motor was bad, compression was sporadic. Not knowing, I ordered the motor from SBT. before putting new motor in, I changed all fuel lines, pulled out the gas tank, completely cleaned and overhauled the whole ski. To ensure I put the new motor in correctly, I bought the alignment tool from SBT, and all shims, checked all motor mounts, etc. I installed the motor myself, with a couple friends with me, one a mechanic and the other a machinist with over 25 years experience. Was just having problems with the ski, so by this time had built a pop off pressure tester from the how to section in the forums and checked my own, was within spec, checked the pulse to make sure was getting correct vacuum, then completely cleaned the carbs again after checking the pop off. put back on, everything seemed to be correct. Also ran the SBT break in oil premixed in the gas, as well as the oil injection, aligned by going two turns in on the idle screw, then setting adjustment, then adjusting idling after. Still could not get ski to run correctly, then lastly, I checked the compression, not thinking this would be the problem with a new motor, and front cylinder was 125, and rear cylinder was 100. This indicated to me something wrong with the motor, so pulled the motor back out of the ski, when I pulled the rave valve caps, noticed the one bellows was deformed and looked to be pushed up, when I pulled the exhaust off, while looking through the exhaust ports, you could see gouges in the sides of the pistons, but roll it over, and you could still see the cross hatchings on the other side of the cylinder wall from where it was honed. The rings on the pistons looked almost to be jammed or welded into the pistons. I called SBT, and filed my warranty claim, and had to ship it back. Yes, I was upset that I had to pay shipping, but not nearly as much as them treating me like an idiot, and saying I obviously ran the motor lean. Now I have raced two stroke four wheelers for years, and I know what a motor looks like that you run lean, and a lean motor and pistons look nothing like the pistons in this motor did. I sent back, and then they put me on a waiting list because they did not have any more motors in stock. I finally got my second motor, got it in, and runs fine, got a little fine tuning to do, as it wants to cut out on top end after only a few seconds WOT, which is either the second fuel filter I put in line between petcock and carbs, or I need to adjust the high speed setting. Yes, I am sure I ranted a little, has cost me the whole riding season messing with this thing, when I ordered my motor at the end of winter hoping to ride this summer, combine that them acting like I was some idiot, and the additional wait and shipping, and I am sure there was some hostility in my comments, but it does not make the facts any less factual, so I felt compelled to express my opinion and recommendation, or lack thereof. That should help to clarify the timing of everything as how it went down, and I am sure there are other sea doo fanatics out there that would have been just as stressed and frustrated as myself.
Short Block Technologies send out remanufactured motors and do not stand behind the product. The motor's are junk, they do not honor the warranty and basically you are buying a product that you could very well be out $3000 if it does not work. We purchased a $3000 motor and after 8 hours two reduction gears broke, they refused to take it back to tell us what was wrong with it and will not honor the warranty. We are out $3000. Do not buy from this company!
Please explain the situation of warranty in more detail. You must have a Yamaha? Why would'n't they honor the "no fault" warranty? Was it a 1 yr. or 2 yr. warranty?
Sunsetwatersports - Welcome to the forum.
It's too bad that your first post was a complaint. I don't have an opinion about SBT as I've never bought from them.
Did they say why they won't take back your motor or honor their warranty?
At $3K did you have them do extra work, I didn't think a rebuild would cost that much.
Good Luck.
So you felt the need to come create an account and make 1 single post adding to a thread from 2 years ago? I dont think people will find this very credible.
I myself have heard of numerous times that SBT did not honor their warranty. Two year old thread or not, single post or not....it does happen.
Dennis - Why did you say "you must have a Yamaha?"
Maybe Sunsetxxx didn't follow the proper break in techniques and ruined the engine....not the fault of SBT then.
But a no fault warranty is a no fault warranty. SBT should cover it regardless of what was the cause.
Seadoobudy, I said Yamaha because their 4 stroke engines have a reduction gear that sunset mentioned. I've never had a problem with a SBT warranty. If sunset took the SBT engine apart in order to see what went wrong then that would void the warranty. I asked the questions that I did because I'm not so sure we're being told the truth. Something does'nt sound right.
SunsetXXX??? SDB, I think you are getting this thread confused with your porn movie collection.
