Loctite?........
According to the manual, the impeller nut is held on by Loctite. The procedure calls for you to heat the center of the shaft to about 300 degrees to loosen the grip of the locking compond.
I used a simple and inexpensive butane torch I got at Wal Mart and it worked great. With the torch set at a fairly low flame, point the blue tip directly at the center of the inside hub and hold it there for about 5 seconds, then try to break it loose.
I sat mine in a vice as Gunsrunner suggested, then used the heat. Seadoo uses that Loctite on every nut and bolt there is!.......
