Hello Everyone,
Displacement, semi-displacement or semi-planing, planing then v, deep v, modified v. I spent several hours reading about hulls and I'm still not clear on this but its beginning to seem that my dreams of owning an Islandia are fading fast.
Here's my situation. I will need to dock the boat in the water at a marina during the season (Ohio). I will not have access to a lift nor float at this time. If I understand what I have read on this forum then the Islandia is gone as well as the rest of the Sea Doo line because optimally these boats should be removed from the water each day. Am I right so far? If so, is this the case because its a Sea Doo, or the case with all jet boats (i.e.Yamaha)? Is it because its a deck boat or a planing boat, all or none of the above?
I have not been able to find clear information on this subject but what I have pieced together would suggest that it is boats with (at a minimum) a semi-displacement hull that can stay in the water. If this is true, it would also seem that there are no deck boats with this type of hull?
I understand in part that the issue with Sea Doos and staying in the water has to do with the growth of marine organisms, corrosion, etc. What I don't understand is the difference between those boats that can stay in the water at a marina and those that can't.
Can anyone clear this up for me? Will I be kissing the Islandia good bye?
Thanks again everyone.
Paul
Paul
