Kyle Thomas
I have a 94 explorer and the hull thru fitting got destroyed when a bearing locked up on the drive shaft. The original part is black plastic/rubber. The replacement fitting/seal was brass. I called up Riva and they said you have to cut the original black rubber part. I do not blame Riva in any way. I started to cut the black rubber part out like you would remove a wear ring. That is not what the guy on the phone ment. Now I have a slot in the bottom of that area. Attached are pictures. Can I just fiberglass the entire missing area or does that need to have some rubber around it as well. Thank you for your help.
