How to tell if my Sea Doo has synthetic oil
mobjack75
I just bought a 1996 Sea Doo which was full of oil. The lady whose husband had had a stroke did not know waht kind of oil was in it. I know you aren't supposed to mix synthetic with non-synthetic oil. How do I tell which I have as I am needing to add oil now?
Well, this is not a perfect answer, but start here:
If the oil is blue/green, then it is synthetic.....and probably an older version of the Seadoo synthetic oil. Therefore, refill with synthetic.
If the oil is brownish, then it could be a newer synthetic oil orthe regular non-synthetic oil.
But if you are in doubt, as timmyboy76 says, simply remove the existing oil from the reservoir (siphon, vacuum pump, etc) and add your new oil. Don't worry about flushing the system unless you already are planning on replacing hoses that are cracked or splitting.
As per sea-doo, the new synthetic blend can be mixed with either full synthetics or conventional oils without a problem.
The 1996 xp will run fine on the synthetic blend.
The color means nothing as to whether it is synthetic or mineral...New, Old, or other wise. This is the best thing to do rather than chancing mixing the 2 together... and seizing you engine over a $6.00 qt of oil.
Here is a step by step to the oil pump oil lines;
After you drain the oil from the oil lines and refill them, you have to be sure there is no air in the lines when the engine starts up or it will cause the engine to seize up. You need to fill the oil lines back up with oil. To drain the oil from the Rotary Valve Chamber, use a shop vac to suck the oil out of the hose…it’s the one that is 3/8” diameter. I attach the empty lines back to tank and fill the tank. The oil line going to the oil injector pump attaches to a elbow fitting on allows the oil to flow to the pump. I let the oil drain into the oil line to the pump first and put a small cup at the end of the oil line, to catch the oil coming out of the end of full line. Attach the full oil line to the elbow on the oil pump. There is a bleeder screw on the pump. Lay a rag under the bleeder screw. Open the bleeder screw till the pump has oil coming out. Tighten the bleeder screw. Be sure the oil is full in the small 2 lines also. Let the oil seep out the ends of the small lines to fill the lines as best as you can. Connect the 2 small oil lines from the pump to the carburetors. Where the cable is connected is a Disk,(pump lever) that the cable is attached to. Check that the mark on the pump aligns with the mark on the disk. Apply the throttle with the ENGINE OFF and check that the cable is in sync with the oil injector cable. They should move open and close at the same time. To bleed the 2 small lines and get the bubbles out, start the engine, on the water hose. DO NOT APPLY THROTTLE. Let the engine IDLE. Turn the Disk,( pump lever) that the oil injector cable is attached to, to full open so the air bubbles travel to the carburetors and leave no bubbles in the line. Don’t run the seadoo for more than a couple minutes on the hose.
For the Rotary Valve Gear Shaft, attach the hose on the tank and allow the oil to fill the hose and attach it to the case. Recheck all the oil lines and be sure they aren't leaking any oil. If you still have any questions give us a shout.
Karl
