Assuming you mean the normal thrashing sound of a compact high-output engine.
Do you have the large plastic engine cover in place?  That helps some.
Foam and dynamat.  Build a separate soft foam lined box over and around the engine.  Same around the exhaust system.
Overall, it is not easy.  Just be glad it's not a diesel.
