O.K., there's a lot of good information on this forum, however except for the post about pointing you to the Mikuni manual, this thread doesn't contain much useful or even good information.
These carbs. are amazingly trouble free, a lot of the time the carbs. just need a good cleaning. Soaking them in gasoline for a few days is going to nothing except remove the finish from the exterior of the carbs., something that's not good in a marine environment.
Remove the carbs. and clean the small fuel filters by soaking in SuperClean and then running hot water through them, clean the passages with carb. cleaner, and re-assemble. The fuel filters are fairly easy to get to, just remove the end block on the carbs, 4 screws and pry out the filters with your fingernail of a small screwdriver.
Check and adjust the hi and low needles to factory specs. and check the pop off.
If you see any worn or damaged parts replace them. If you feel that your carbs. need a complete overhaul, go by the manual or PM [MENTION=16022]Dr Honda[/MENTION] and see if he can do them for you.
Lou
