H hedberg New Member Oct 26, 2010 #1 how will i save my engines on my sportster whit 2x 85hp rotax to not be frozed in the winter? Will i put frozen free water in the engines? or its no whater in the engines if i start them litel whitout whater?
djredman99 New Member Oct 26, 2010 #2 hedberg, Download your Owners Manual from BRP web site here: http://www.operatorsguides.brp.com/...ang=E&s1=974c1f82-d07d-4534-9d50-1972788a3362 Be sure you select "Sport Boats" from the drop down, select your year, and model. Under the maintenance section of this document will be directions on how to winterize your boat. Also, you can try searching this forum for "Winterizing Sportster". Here is one of the links that comes up : http://www.seadooforum.com/showthread.php?t=242&highlight=winterizing+sportster If you continue to have problems after reading, post additional questions.
djredman99 New Member Oct 26, 2010 #3 hedberg said: Will i put frozen free water in the engines? or its no whater in the engines if i start them litel whitout whater? Click to expand... YES you will have to put Antifreeze (frozen free water) into the engines. Even with running the engines without water going in, which is not good to do for very long anyway, you will NOT be able to get all the water out. Do you best to read through the posts and document link I provided above.
