How much oil is consumed...
premix does sound good for now. I use 40 to 1. you seem to have an average of 200 to 1 if you are correct about 25 gallons of gas and 1 pint of oil if my math is correct. premix sounds good untill you are sure your oil pump is woking properly. good luck
Just an update...
I tore apart my oil injection system and found that between the first owner and myself, we had mixed synthetic and mineral oils, and I had a nasty Jell-O sludge in there blocking, or at least severely inhibiting, my oil flow.
So, keep an eye on that oil, and if it doesn't look like it is flowing enough, check it out...it just may NOT be!:cheers:
Luckily I caught it before serious damage was done, and was premixing my gas a bit.
