ProfitOfDoom
The rubber boot in the pic,when both clamps tight,when you crank the engine the rubber sleeve on the drive shaft will twist and not stay in place,can anyone explain what im doing wrong or what is wrong with this?
This looks like the right boot for 1995 and older unless someone changed it out to a older style.The bearings in this boot are bad and need to be greased every time you take the boat out. You can buy the hole asembly prety cheap that is what I would sugest. :cheers:that dosent even look like the correct boot. should look like a cv shaft boot. that looks like a piece of radiator hose or something...........
Are we talking kawasaki or seadoo?:cheers:this is what mine looks like, diff model but should be close to the same. my 440 and 550 both have these style boots.
