Hooked up battery up backwards in a xp 96 seadoo
that dude
:confused:So far i have try'ed looking for the fuses and the two in the back black box are good.The other two up front in the gray box are good as well :confused: I've charged the Battery fully.I have try'ed pushing the start/stop 5x i get one short beep and the sec that seem to be a little longer then the first,gas gage read oh yes this was all done with the dress off.I' then put the dress on then try to start and two more beeps with the top two light flash,and when i had push the start/stop button while doing the first step all four lights come on and stay on till the sounds of the beeps.I've jump across the c the starter turns for a sec or two with spark's.Is there a ground wire that lead off the starter:confused: I have the one from the battery to the starter.this wire to get really hot when jumping straight to the starter.I can only get the pos+jumping cable straight to the starter.Then i just tap the ground wire from starter to jumping cable neg-:confused::redface: Thk's for your time if you had read this Thread
