High speed screw initial setting?
scooper77515
freebie fixer
Premium Member
The book says 0.
Does that mean seat it and put the cap on it?
Rebuilding the carbs, only reason I am messing with this.
Wow! I have never heard of having a needle that is seated and left that way.
So, the 1/4 turn of available adjustment is only rich...
I guess it is best to leave it at zero.
What about the low speed? I have seen suggestions to set it at 1 out, and another line of reasoning saying to set it at 1.75 out. Even though the book calls for 1.
Any ideas/suggestions on that?
I was running it right at 1 out before I rebuilt them.
Just like on a chainsaw, set it at the book setting, then take it out and adjust on the water (or leave it alone)
High speed screw?.....
The high speed adjustment screw is actually a "bypass" screw. The fuel porting for the high speed jet is fed directly into the venturi from the fuel chamber. The high speed adjustment screw can be opened off "0" to add additional fuel if necessary. You'll not normally need to mess with it if the jets are clean.:cheers:
