2008 rxtx oil leaking HELP
hi everybody
this is i real weird problem , need help before i go back to dealer ..
i have a rxtx 2008 255 hp . last fall it was leaking water in hull so took it in and they replaced carbon ring ,nut stop elastic din 985, i also had a oil pressure switch replaced , do to it was coding around the time it was leaking , so they fixed both ,under warrenty.. winterized it , all good to go ... well i thought ..
I went out yesterday to river , was going to go for a ride , but i thought i would leave on trailer and back in water and start it up , so had seats off etc , and was running it ,looking for leaks etc , about 4 min into it i turned it off checked oil level ,it was good . started it again for another couple min . pulled it out of water , put seats back on . figured all good to go so just before i was going to back in water again and go for ride, i thought for whatever reason to take drain plugs out just to see if it was leaking or if there was water in the hull, i took plugs out and i bit of water came out , but then oil came out , lots of oil .. it ran for a bit ,i checked oil level , there was no oil there ...what the hell happened . i lookked for 3 hrs to see where its coming from... cant find it... could it be something the dealer did.. i didnt do anything to it since they touched it .. is my supercharger screwed.. like i said , i think teres a bitof oil in there ,ad it was just idleing in water .. can someone help please
hi everybody
