Help
On a Merc engine?? (assuming it's the 2000 sportster 1800)
Nope. Just need to pop off the flywheel.
LOL !!!
OK... I was thinking the power stator.
No... you don't have to remove the engine, to remove the pump stator. It will unbolt from the pump end. Basically, remove the reverse gate... the nozzle, and then you can unbolt the stator.
Do I need to pull engine to remove stator to have it rebuilt
The reverse gate and nozzle can come off as one unit, you don't have to remove them individually. Make sure you unbolt the trim plate from underneath, you don't have to remove the actual trim adjustment nuts.
Thanks guys you all have been very helpful and have great information . Everything is off but wear ring and impeller need to get socket and crows foot. Thanks again
