Help!!!!!!!!!!
tubberburkett
first i'm new here and i'm new to the jetski world this is my first one, i bought a 1994 seadoo xp and the impropeller was mod to make it go faster and boy dose it my problem is when u mass the trigger to take off it like build up the power then it will go or some time it chock up like it want to cut off and it will if u dont let go of the trigger, its get me creazy, i have to set there sometime and play with it (trigger) to get it to go but once ur going it dose right as fas as going faster or slower but when u stop and start up again it will do it again, lets put it this way i cant pull a ski or wake or knee board they will sink before i can get going, so please any help will be greatfull. i really dont have the money to go pay someone unless i know it will fix the problem with out spend hour looking for the fix and i know some moter skill just tell me where to start.....thanks for any help...
The carbs aren't bad to clean, but a manual would be your cheapest and best investment. The manuals are in the premium section for $10.95 for the month.
This might be a good idea for you.
Here is some more information on the "Premium Membership";
As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
thanks guys i just got a repair manual downloaded from another site didnt know ya'll had them here' i'll try this and let u guys know if that work once again thank ya'll
most likely u wont even have to take the carb apart, theres a little filter in the carb thats probably dirty, clean that, and u should be good to go!
