I'm trying to identify the fuses as there are 4 fuses, 1 is the bilge pump with brown wires, there is a orange wire, red wire etc. Which one is the fuse for the voltage regulator to charge the battery?
I would have to pull up the schematic for your boat... but generally, none of them are for charging. The larger fuses just feed your main fuse block. The charging fuses is on your MPEM.
Thanks Dr Honda, i found the fuse near the solenoid. I need to find out if the voltage regulator is the issue or the negative and power cable i replaced to keep the battery charged.
