Sorry if this has been covered before. I'm trying to understand the low oil warning system. More specifically where each indication, son-alert and light get the signal from and what other circuits tie into it. It looks like both signals come from the ECM. The blue/Wht wire coming off the engine goes to the light on its own and the tan/blue goes to the son-alert through the engine harness plug. The light is working intermittently and the son-alert doesn't. Checked continuity on the resavoir cap and I can get the light to come on (although I usually have to giggle the kill switch?). But I can get the light to go out by moving the float switch to simulate full oil tank. I tested the alerter and it works fine. I can't tell if the signal for the alerter is being sent from the ECM. Is the ECM just supplying the ground? Any thoughts?
