HELP Updated
so it actually worked, i now get exhaust plumes coming out of the rear, which i wasnt before, but still same issue. runs 3 sec and dies......
Took the vst apart and drained the fuel into a glass and looks like I have water in my gas tank, emptied the vst out and re installed then took it off again and more water so I guess I ha e to drain the tank now…good times…IMG_2387.JPGIMG_2386.JPG
Just use an oil extractor to suck up the water,,,or,,,syphon the water out,,,is this carb'd or injected?
Ok so, changed out the high pressure fuel pump in the vst, can now hear it running and probed it, it is getting power, however still no pressure reading from the shraeder valve, double checked polarity and is good, starts really well and the. Dies after about 3-5 seconds. Where to look/test next?
