2012 GTX 155, 4-TEC, no turbo. Removing the oil thru the dipstick tube using an extractor tube with black electrical tape at about 18 inches up the tube to mark the proper insertion depth (as specified in the manual to do). I push it in a little too far and when I pulled it out, no tape! I'm 95% sure it went down the tube. Tried fishing it out with wire but no sign of it. I presume it found it's way into the oil tank. Dealer says that if it blocks the oil intake filter it will grenade the engine or at least set off the alarm. I ride far out so I need reliability. Dealer says only way is to pull the engine for lots of dollars. I thought about threading a scope down there but not sure I could find a scope small enough and if I would be able to see anything conclusive. Even if I did, I'd still have to get it out. The early questions I have are: Is it really a problem? Is there a way to get to the oil tank easier (cheaper) than pulling the motor? Are there any less expensive ways out? I'm in Seattle in case any experts are near. THX!
