gullwingcorsair
I have read and tried several different methods on removing the jet pump from my ski.
It has a crazy amount of silicone between pump and bulkhead. Also bolts do have corrosion on them(saltwater use), which I'm sure is not helping. I'm betting shaft is also stuck in impeller.
I need to get this off to repair Shaft/Thru-Hull fitting, new wear-ring and probably new bearings and seals.
Any suggestions would be great!
Thanks
Stu
Thanks
Stu
