WhiteZombie
So the guy I bought the boat from said he had seals changed at the first of last year. The Port side looks like what he was speaking of. I'm not 100% on what I'm seeing with the right side but I assume that groove to be a wear ring indicator type thing after skiming over the manual. I was looking for a tolerance on shaft "play". I will check it with an dial indicator tommorow. I do know the port side has the lesser of the two play wise.
What do I need to do here? I'm pretty much done for now with the engines as long as they fire up with the new carb rebuild. I'm putting it back together now. Electrical has all been gone thru, so I guess I'm working from flywheel back now. I've read some about the carbon seals and the neoprene seals. I plan to check the clearances as specified in the manual, but it really doesn't say how often to change these in the service manual, but seems like I recall 2 years or so from something I read or was told. I think the Operators Manual mentions them.
Anyway, any suggestions are appreciated. I know I'll be doing some work on this boat during the winter, probably pull the heads and hone, etc, so if I have some time here on these seals I'm good with doing it then. Don't want to flood the boat tho before that. And any other suggestions are always appreciated if you have experience with these boats.
Is Dr Honda still on here? I have some machining questions for him on this 717. Seems he mentioned several times he is very knowledgeable about machining these engines.
Thanks
Thanks
