Just bought an immaculate 2005 Sportster, 155, 4 tech. Runs great,
but steering was a little tight. Started to take apart to install a new
steering cable and behold everything is salt frozen. Previous owner
never did any preventative maintenance.
Looking for some tips to break loose the pump and steering assembly.
Drilled bolt heads off but still can't break steering casting loose. Removed
the four nuts holding the pump in place, but can't beak the pump loose
from the frame. Tried heat and penetrating fluids with no luck.
Most of the casting are unavailable so I'm trying to be conservative in the
removal but will try anything at this point.
Thanks in advance for any help
