sledman1
Looking for some help on a 1998 GTX Limited (951). The engine starts and idles but sputters and backfires once you give it the gas and you get above about 1500 RPM’s. 125 psi compression both cylinders. I have swapped out the gray fuel lines. Cleaned the carb filters. Tried a second set of carbs with the same results. Cleaned the RAVEs and also tried a second set of RAVEs with no change in performance. Removed and inspected the Reeds. Tried running the engine with a fuel line going directly from the carbs to a gas can. Again no change in performance. Also tried spraying gas directly into the carbs while running the engine with ¼ throttle applied with little affect on the sputtering and backfire. I sprayed some carb cleaner at the PTO end of the motor while it was running to see if there was a bad crank seal on that end. No affect on the idle when I did that. The backfires are kind of a hollow sounding backfire. Not a real loud type. What is this type of backfire an indication of? Running lean? Timing? Any idea’s as to what else makes sense to check would be greatly appreciated. Thanks, Don
