rbbengineer
i rebuilt my carbs did everything right adjusted carbs to spec has 140 psi compresion both cylinders took to the water ran 5 min very well went to go back to dock and then it bogged out and stalled it restarted but continued to bog was running before rebuild but now it bogs when given gas rebuilt because leaking gas from carb had hole in rubber does run jut boggs oil pump was tested used drill oild dripped out injector tubes while out in water noticed the exaust pipe had pin hole in it at one of the aluminum disks on the upper exaust tube fixed that still bogs though can anyone help
