diabloflash
HELP! - 98 Speedster Oil Bleeding (Solved)
Hello,
I just pick up a 1998 Speedster Seadoo Red (787 Twin Engines). The big plastic oil tank had a small crack in it causing a leak. Took off the oil tank and filled in the crack (Leak tested) and everything seems fine. I reconnected the tank and the oil lines. I started the bleed process by unscrewing the oil bleed screw on the port side engine, with in seconds the screw hole for the bleed screw started leaking out oil. However the starboard side engine, I unscrewed the bleed screw and nothing...? no oil came out, 5 minutes later again nothing. whats up with that?
Anything I should try and do?? Is this ok?
Solved: Simply, make sure your on level ground and that the boat is level. Even if the one engine bleeds well, doesn't mean the other engine will!!!
Hello,
