diabloflash
HELP! - 98 Speedster I missed up big time!! MPEM may be gone
** SOLVED**!!!!
98 Speedster went to put in speakers and started cutting out the holes and end up cutting through the wiring harness....
Wow I feel stupid... I split half the wires and the main power was on.
I turned off the main.
I reconnected the slit wires with solder and shrink wrap.
2 fuses were popped Mpem(1) and the gauge(2) replaced
now the boat doesn't start, doesn't even turn over
I connect the key no beeps... before it beeped twice.
if I push the start button 5 times I get 1 short beep then one long beep then nothing...
Any hiding fuses or something I can check to see if I burn out the Mpem. maybe something with the key?
So Sad
So Sad
