OK WELL THE PROBLEM IS THE SKI RUNS GOOD FOR ABOUT A MINUTE OR TWO THEN BOGGS DOWN AND WONT GO MUCH HIGHER THAN IDLE SPEED WHEN YOU LET IT COOL OFF IT WILL RUN GOOD AGAIN FOR A MINUTE OR SO BUT IF YOU IDLE FOR A MINUTE OR SO IT WILL TRY TO GO BUT WILL BOG AFTER A SECOND OR TWO I CHANGED THE FUEL LINES ,THE FUEL VALVE RODE WITH GAS CAP OFF THE SPRING IN THE WATERBOX REGULATOR BECAUSE IT WAS BROKE IN 2 PLACES ALSO BLEW AIR THROUGH THE REGULATOR NO CLOGS. PULLED CHOKE WHEN IT BOGGS AND IT JUST ALMOST DIES SO IM LEANING TOWARD ELECTRICAL PROBLEM OR THE MOTOR IS SEIZING CHECKED THE COOLING LINES AND THEY ARE CLEAR, I PULLED ONE OFF WHILE RUNNING ON THE TRAILER AND IT SQUIRTED OUT A NICE STREAM,UNPLUGED THE RED WIRE ON THE RECTIFIRE ,CHANGED SPARK PLUGS ,THE HEAD STAYS COOL BUT THE CYLINDERS ARE GETTING A LITTLE HOT NOT REALLY BURNING HOT BUT HOT IS THIS NORMAL ?also rode with seat off BOTH CYLINDERS COMPRESSION IS THE SAME 135 PSI BUT MY GAUGE READS A LITTLE LOW .ANY OTHER THING I SHOULD CHECK
THANKS ANY HELP WILL BE GREATLY APPRECIATED
