JOHNFLAGG
Motor was not running,I had rave valves out and spark plugs out,checking the clearance for new rave valves,In the process i was doing, a small nut dropped and found the opening for the spark plug and dropped into the cylinder,(I couldn't hit the hole if i was aiming for it!!!)I removed the 2 piece head to get nut from the cylinder,My question is ...when i re-assemble the head pieces to the cylinders with new O-rings,What type of sealant should i use...Looks like the last owner used a bunch of clear sealant on all the surfaces,thanks guys,787 motor
