martymrgrin
I need someones help or advise.
I installed a stator today on my 99 gtx limited 951. It was grounded.
After the install, i hooked it up to the water hose to check the voltage. Battery has be on a trickle charger for 2 days, so it was fully charged. When started, the voltage reads around 12.75 at about 2500 rpm. 13.25 at higher rpm. When i hit the gas to check it at higher rpm, it reved up and stayed upeven with my hand off of the throttle. Not sure what rpm it got to. I hit the kill switch and it would not shut off. I had to remove the key to get it to shut off.
Is the higher rpms something that happens when running it on the water hose? Should i be alright to put it in the water?
Thanks for any advise or comments.
