AS far as your question regarding maintenance....not really a lot of maintenance you can do.....keep the oil up (use the right oil), make sure the oil lines don't/aren't leaking, check the ski interior for signs of oil leaks often (the tanks tend to crack possibly), use fresh fuel, keep it clean and flushed (if used in Salt water).
If you have an end of season......clean and flush it, run it out of gas or stabilize the fuel in the tank and fuel system, top up the oil system, fog the cylinders with fogging oil, open the drain plug(s), tilt the ski to drain properly, pull the battery (store it indoors and keep it charged properly), properly cover/protect/shrink wrap it and tuck it in a corner somewhere safe....that's all I got.
