oceanrider
I am running out of options - except the dreaded dealer diagnosis. Here's the scoop. The starter is OK, been checked, there are two beeps when the lanyard is inserted. Now, I replaced the lanyard switch today - it seemed to react to the wires leading to it being bent one way or another. But I am still unable to start the ski. I get the two beeps and no gauges. If I plug in the battery tender, I get the two beeps and the fuel pump starting sound, as I should, but then as I start, I get a long beep indicating a wire harness problem. And the gauges go down.
I got a new post switch today - same symptoms. I tried jumping over the solenoid, but at that point the I cannot even see the gauges, the inserted lanyard does not seem to be recognised.
The battery is abut two year old, but it has been always in the battery tender and reads 12.5 V on the meter. The tender indicates it's charged. The nearest I get to starting up is a click or two from the solenoid, but only when the tender is plugged in.
Is the battery the culprit...>?
