Welcome Gunnar!
Welcome to the forum Gunnar. Glad to have you here!
I've read your post and your symptoms are indicative of a worn out or damaged wearing ring. That's kinda hard to bite because I see your Doo isn't that old. A wearing ring, under normal riding conditions should last upwards of 7 to 10 years.
I'll go through the manual with you on Wednesday and see what else can be dug up on it but it does seem that your wearing ring is gone. One other possibility is that with all the power that the 4 TEC generates, makes me wonder if you've spun your shaft (stripped out your splines on the impellor). If you spun your shaft, it will have a strange sound to it. A zipping kinda sound. A bad wearing ring will only keep your from building thrust, there isn't any difference in engine sound.
To remove the pump is fairly simple.
On page 234 of the volume 2 manual for the 2005, you'll see the layout on pump removal and repair. After you remove the 4 nuts that hold the pump on at the transom of the ski and you've removed the water inlet and bailer tube inlets from inside, grasp the pump and wiggle it pretty hard from side to side and up and down until you break the watertight seal. After you accomplish this, it should just slide out. That seal can be stubborn, so don't give up.
