O ogkustoms New Member Jan 29, 2010 #1 anybody know if a 1995 xp 717 motor will work in a 1998 gts? crank cracked in mine after I replaced the rotary valve and cover.
seadooya Premium Member Premium Member Jan 30, 2010 #2 It'll work, but i suggest you use the intake manifold and carbs from the XP. accellerator pumps are good, but no "lag" w/ the twin set-up...but either carb set-up will work. Where-abouts in cal. are you?
