Welcome. I forgot to post a link to the Mikuni carburetor manual. Mostly from this you can see the three paths for fuel flowing through the carb, idle circuit, part throttle low speed ("bypass holes") and high speed venturi circuit.
At diel, fuel is only being metered through the idle mixture low speed adjuster needle, just enough fuel to keep stoichiometry while idling. On throttle tip-in, the "pilot holes" transition ports begin adding fuel as air velocity through the carb bore increases. Most of the actual fuel consumed is provided by this transition circuit, unless you're a genuine lead-foot. These are the small passages most prone to clogging and very important for low to mid throttle operation until air velocity increases enough to begin pulling fuel from the high speed venturi.
It's VERY common for those "Bypass holes" to become cloggrd or partially clogged, these passages are precision drilled in the aluminum bore and prone to close up slightly as the aluminum corrodes, the small diameter makes them a great place for trash to collect as well. The "Bypass holes" are the most important passages in the entire carb b/c most of the fuel is metered through them.
The high speed circuit is constructed using raher large passages to meter large amounts of fuel at wide throttle angle and air velocity thus usually aren't clogged or restricted due to large diameter.
Then there's the atmospheric-pressure referenced vacuum operated metering diaphragm, which shuts off fuel from entering the fuel chamber when there isn't much, or zero, intake manifold vacuum. When operating as intended, mostly this has it's greatest effect on low speed operation, and most important keeps fuel from peeing down into the intakes and fuel-flooding the crankcase when the engine isn't running (when there's no vacuum).
http://www.mikuni.com/pdf/sbn_manual.pdf
