You should look in the shop manual for your ski and there is probably a resistance check you could perform to help you determine what is wrong. If you replaced the float then other things that can cause problems are the wiring, internal F1 fuse or reed switches. Most common failures are wiring issues, float and F1 fuse. I think if you measure the resistance between the 2 wires coming from your sending unit and it measures open then it is either a broken wire or the F1 fuse is blown. If you google seadoo f1 fuse there are lots of references and youtube videos to help you.
