bigJake
Factoid #1:
"Electricity is the flow of electrons. Voltage (measured in volts) is the pressure that is pushing the electrons. The number of electrons flowing is the amperage (1 amp is when 6,241,000,000,000,000 electrons flow past a point in a second).
Resistance (measured in ohms) is the resistance being offered to the flow of electrons. The relationship between these three quantities is called Ohm's Law: Volts = amps X ohms. Running current through a component causes the pressure to drop. Voltage measured before and after the current goes through a component will show a voltage drop."
