JEasterhoff
I have a 2007 Challenger 1503 SCIC that left stranded on the water. It's a new boat to me so I don't know much about it. The main issue is the fuel pump doesn't come on with DESS attached. I tested, there is 11.3vdc at the connector for the pump, but the battery voltage is around 12.9vdc. I have 12.9vdc at the fuses, so it seems to drop voltage through the wiring harness. I put the fuel pump directly on a battery and it starts up. I have cleaned up the battery connections and the grounds on the block. It helped but I still have voltage drop. Is the pump just wore out? Or is the voltage drop more of an issue? I also found the wires melted on the stator connector so my battery was prolly not charging. Thank you for your help!
