Nate (a junior immature boat mechanic) speaks:
Why bother cleaning up all the goop from the fuel lines, and carbs, and then LEAVE any source for more of that goop.
It took me ALL day to clean my carb filter. I used (from memory) Silicone spray, brake parts cleaner, carb spray cleaner, Ultra sonic jewelry cleaner, with vinegar, and finally got it perdy and white.
My point is that I hated what the gray lines did to me so much, that as a matter of principal, I changed all the lines. I somehow think that as the gray lines get OLDER, that they disintegrate faster. And, just a good load of glue from a vent line could partially clog things, and cause a lean engine condition, and so with all things considered, you MIGHT get away with it, and you might not.
Err on the side of caution, and throw those gray lines as far as you can!
My 2 cents.
Nate
