fuel gauge not working
robman66
The low fuel light will come on and the alarm will sound, but the gauge will not indicate the fuel level. Any ideas?
Thanks
normally the float in the sender will go bad. But if you are saying... the system is still working... and the light/alarm will come on, when the fuel is actually low..... then I'd say you have a bad gauge.
It could be as simple as a loose connection as well. There is a water tight three pin connector at the sender you should check, and check the connection at the gauge.
