oh that would help lol. sorry forgot.
it's a 03 challenger 1800 with the 210 m2. also I took a look at the back of the ignition switch and the yellow w/ black tracer, which is the wire to the solenoid, is just hanging there. no connector, no nothing, just bare wire. or is the choke automatic?
This is from the manual:
Enrichment System
The Turn Key Start (TKS) Electronic Control Module (ECM) electrically controls the enrichment
valve to provide a rich fuel charge for starting a cold engine.
The TKS ECM monitors engine coolant temperature (thru the temperature sensor) and
ignition timing.
The TKS ECM electronically opens the enrichment valve for varying lengths of time – the
colder the engine, the longer the valve remains open. The TKS ECM also advances ignition
timing – Below 3,000 RPM the TKS ECM advances idle timing 5° until the engine
reaches 104°F (40°C). Above 3,000 RPM, the TKS ECM does not affect ignition timing
regardless of engine temperature.
Fuel is gravity fed to the enrichment valve from the top carburetor float bowl. When the
valve is opened, fuel is drawn to outlet ports on each carburetor flange by crankcase vacuum.
During cold start, throttle shutters should be closed – maximizing crankcase vacuum
– to draw ample fuel from the enrichment valve.
Fuel Enrichment operates as a function of time and block temperature.
a. Enrichment valve will continue to provide fuel while engine is cranking until block
temperature reaches approximately 122° F (50° C), at which point it will no longer
provide fuel.
b. When block is hot (normal operating temperature – 140° to 155° F) enrichment
valve will provide fuel for approximately 1/2 second when key is turned to “ON”
position. The valve will not provide fuel during cranking at temperatures above
122° F (50° C).
And....
Manual Operation of Enrichment Valve
IMPORTANT: Manual use of enrichment valve if engine is warm could result in engine
flooding.
Should enrichment circuit of TKS ECM fail, press button on enrichment valve and hold
approximately 5 seconds. Release button. Start engine.
So... The "choke" is electronic.
