Jnz
I have a fuel delivery issue on my 98 speedster twin 787s. On the right engine everything runs fun starts right up and fuel filter is full. The left engine does not start right up and does not fill the fuel filter and seems to use the the fuel then die. I was chasing the issue and tested the diaphragms in the fuel pumps and the could not hold any pressure. So I replaced both fuel pumps with the high flow mikuni pentagon pumps and routed each outlet to each inlet on the carbs. Got some advice from a local power sport mechanic and he suggested switching the input line from the engine that fires right up to the problem engine and vice versa. The problem engine fired right up and got fuel In the filter and the problem went to the other engine. Now I know the problem has to come from either either the pickup leading to the fuel pump Inlet. Pulled the lines and plugged one end of each and it's sealed no cracks. I am using Fram g2 filters and can't see anything wrong with those. I pulled the baffle, but don't don't know what could be wrong given it pulls fuel for one side just fine. Any suggestions ?
