seadooer2022
What do you guys think of this? Got it for free, been sitting outside for a few years. It's a 3 seater with a 657, dual carb, hull id ends in 94. So I think it's a 94 GTX. Everything seems still intact.
Removed the plugs and was able to turn it over by hand. Removed the intake/carbs, small amount of water came out of the rotary valve holes.
Removed top end cover, and gave it some fogging oil, turned over a little easier. Seems to be some rust stain between the piston and the wall? Not sure
What to do next? Check compression and see if it fires up?
