Flushing using a pump
demt1992
I have a 2004 Sportster 155hp. I have a utilitech submersible utility pump, 1/6 hp, rated up to 25 gpm. Ia that too much pressure to run antifreeze through for flushing?
Flush port has a built in restriction .. should be safe
As always….engine on, water on, water off, engine off.
You are the first to tell me that. I have been concerned it would be too much pressure. This is the pump I have.
tobytd...after posting a picture of my pump. Do you have any further thoughts or am I still good to go?
Thank you.
