I just picked up a 2001 Sportster LE. I haven't had it in the water yet. It cranked up and ran although it smoked quite a bit. I'm not really worried about that. If it needs a rebuild then so be it. My daughter was cleaning the boat yesterday while I was at work. (It's really for her anyways) She was cleaning the engine compartment of all of the oil all over the place and walked away for a phone call leaving the hose running. It completely submerged the engine. We let it drain out. Unfortunately the bilge pump was not working. I pulled the plugs and turned it over and it spit a lot of water out like I would expect. I have been steady working on getting the water out all day today by pulling the plugs and turning it over as well as putting the plugs back in and turning it over more. The plugs come out white and milky every time. I have tried to fire it like I have any four wheeler I've flooded before and I simply cannot get this thing to fire back off. Foggin oil has been sprayed into the carbs and the cylinders. I'm at a loss at this point. Should I pull the carbs and jugs off to see what's in there? I've never worked on one of these engines before but I'm definitely not foreign to doing the work. At this point the starter is likely shot too as all I get now is a click. I ordered a new one from SBT. Any good advice would be appreciated.
