Flickering Battery Light
Broosedamoose67
So I just got my ski back and took it out for a ride this morning and out of the corner of my eye I saw a flicker. I started watching the cluster and every so often the battery light flickers. Seems like a loose wire but I checked everything and it's all tight. Could this be the rectifier going bad?
What model year? I would check the fuse box and fuses. The fuse recepticles can corrode or loose their clamping force over time and result in intermittent and unrelated electrical gremlins. Had a similar issue with my 2016 GTX.
Turned out to be the one connection I didn't check; the positive battery cable. :( I had just put a new battery in it so I assumed they were tight!
