first day on the lake
harley_enough
hi i was jus wandering if anyone could tell me why my 99 challenger seems to bog down so to speak under full throttle acelleration? if i back out of it jus a lil then she is fine.. but it doesnt do it every time. and i also noticed when i hit the gas and turn the wheel it seems to cavatate...this is my first jet...otherwise the boat seems real nice...little hard for me to get used to at low speeds but i guess practice will help...btw i should have stated when coming up on plane..when im crusing and i hit the gas she is fine.
The cavitation is from an air leak, and in a turn, it will get worse. Either you have high clearance in the pumps, or the carbon seal on the driveshaft is starting to leak.
The bogging is BAD !! that's a sign that the engine is going lean. I would check over the fuel system for a leak, or a plug. And... rebuild the carbs.
