prairieboy
Sorry for the long post, but I'm hoping one of you more experienced mechanics can tell me what's going on.
Finally had a chance to finish buttoning up the top end on my speedster. Had to go 0.5mm over. I aligned the cylinders to the exhaust manifold and torqued everything down to spec. Before I put the head back on I thought I'd better check to see if it spins freely by hand. Added 30ml of 30 weight to the counterbalance as well.
It turned over real nice for a good half dozen turns then would just find a spot and not turn. If I back off a bit and try turning again it would spin. I tried both directions and same thing but not in the same spot as far as where the pistons were in the cylinders.
I know for a fact nothing went down the crank and when I had everything apart it spun freely.
There's no clunk or metal on metal, more of a softer stop and it would take a lot of effort to finish the rotation.
At this point I figured WTH and buttoned everything else up.
With the plugs out, I hit the starter a couple of quick times and no smashing apart - haha. So I put the compression gauge on and 150 on both cylinders. K - so I'm starting to smile a bit.
I hooked up the water hose and put the plugs in to prime the oil pump and she fired right up.
Ran it a good couple of minutes on the hose and it idled real smooth and no harsh noises, but I guess I'm a little gun shy at this point.
I was hesitant to post thinking I would hear the truth about something bad, but I figured I gotta figure this out before it drives me nuts.
So, good or bad? Haven't obviously had a chance to do a water run as winter is settling in real quick here. At 3000 rpm out of the water and it ran and sounded ok - should I still be concerned or should I expect the worst next time I put it in the water and perform break in duty.
Sent from my LG-D852 using Tapatalk
