For the second time since we got it we tried taking our boat out (2003 Sportster 951 Carb) and it was a no go, first time was weather related, this time I had a couple of issues.
1. The boat WILL NOT steer to the left and I am completely lost-the boat hasn't been in the water since I replaced the jet pump and driveshaft and when I got it in the water today everything was good, no issues with forward/reverse, engine ran great and the jet nozzle turns fine both directions when you turn the wheel on the trailer but in the water the boat will only turn straight and right any ideas what could cause this? Cable issue? It doesn't make sense because it turns fine both directions on the trailer.
2. No water comes out of the hole on the swim platform at idle, is this normal?? It does come out once the engine is revved up but not at idle in the water, hooked to the hose to flush out it sprays out fine as well.
Thanks in advance!
~B~
Thanks in advance!
~B~
